2007 Ford F-150
JIMHEN46
  • 2007 FORD F-150
  • V8
  • 4WD
  • 38,000 MILES
Gas cap was loose and emission light came on, can it be reset
Tuesday, March 9th, 2010 AT 6:43 PM
BMRFIXIT
  • 19,053 POSTS
If check engine light on
should check for codes
need to use an OBDII reader, scanner
to reset check engine code also an OBDII can do it
or disconnecting negative side of the battery for few minuets will do
the only thing with disconnecting the battery is that all additive memory will be lost and PCM have to relearn it all
so you may experience stalling or hard shifting...
Tuesday, March 9th, 2010 AT 8:07 PM
