Coolant in the oil?
BLACKOUTFORD
  • 5 POSTS
If what he said doesn't prove true, try checking the valve cover gasket-it may be leaking from the coolant passage to the timing gears and pumping straight from the pump to the crankcase.
Thursday, June 18th, 2020 AT 1:09 PM (Merged)
WENDYC
  • 1997 FORD F-150
  • V8
  • 4WD
  • 220,000 MILES
Thank you so much for all the info. Can you possibly send me the list you were referring to? Also, do you have any idea what another motor might cost? Any ideas where to look for one? Of course, we are not sure what is exactly wrong with it yet. Have to take it and someone check it out. Again, thanks so much for all your help!
Thursday, June 18th, 2020 AT 1:10 PM (Merged)
BLACKOP555
  • 10,371 POSTS
Please reply to your topic you already started not another.
WENDYC
I am new to this site and I didn't quite know how to navigate around it!
FLEXY5
  • 512 POSTS
No problem, I can send you the list. For future postings, after you log in, you should see three options to the rightof the page, just below the log in options. One should say "view you posts." Select that to find your original post. I'll post on that one.
8)
WENDYC
  • 1997 FORD F-150
  • V8
  • 4WD
  • 220,000 MILES
My husband was driving home today and his truck started making a "noise". He was watching his gauges and the truck never ran hot, temp had increased, but not to the running hot point. He checked the water reservoir and it was empty. He filled it back up, the noise stopped. Water reservoir became empty. He filled it up again, drove a little ways, noise started again, stopped checked water, had small drops of oil in reservoir. Took water pump off, drained oil, there was approx. 4 to 5 gallons of water in oil. What could this be? Blown headgasket? Blown intake gasket? Bad water pump? The truck never ran hot, never had steam coming from under hood or tail pipe. It has the 4.6 liter.
BLACKOP555
  • 10,371 POSTS
Sounds like a warped/cracked head or a bad headgasket, the intake manifold wouldnt do that more then likely, and the water pump shouldnt either,
perform a compression test to check or you can fill up the radiator till no more air comes out, start it up and look for bubbles to appear, bubbles indicate a blown head gasket.
You should also put compressed air into each cylinder and if bubles appear or the cylinder wont hold air then its a bad headgasket or warped/cracked head.
KIRBY102091
  • 1997 FORD F-150
  • V8
  • 4WD
  • 120,000 MILES
Hi I have a 1997 ford f-150 that has the 4.6 liter triton v8. I am experiencing a problem where the engine oil is mixing in with the engine coolant, but the coolant is not mixing in with the oil. Do you know what could be causing this problem.
  • 109,896 POSTS
Can you tell if it's engine oil or trans? Chances are the oil cooler is bad leaking into the cooling system.
