2004 Ford F-150 will not start
PLUMKRAZY
  • 2004 FORD F-150
  • V8
  • 4WD
  • 83,000 MILES
Stater selonoid is good, battery is good, stater is not engaging wen the key is turned but wen grounded by the selonoid the starter works. Could it be a relay? Or an ignition switch?
Tuesday, June 8th, 2010 AT 2:42 AM
On the starter relay short out the small terminal label S to the battery terminal on it coming from the battery did the starter engage the engine if so-check the transmission range switch and ignition switch
Tuesday, June 8th, 2010 AT 5:38 AM
PLUMKRAZY
Wen the key is turned it makes a click sound from the fuse box on the passenger side, everything else works fine wen u short the selonoid it engages fine and turns over, but by doin tht it doesnt have a good enough current to start, so im guessing the igniton switch?
Tuesday, June 8th, 2010 AT 6:45 AM
