2002 Ford F-150 won't start
MOEFEENEY
  • 2002 FORD F-150
  • V8
  • 107,000 MILES
My truck has been randomly not starting and it seems if I either leave it for a while or keep messing with the ignition it'll start after a couple of hours, what can I do?
Thursday, September 17th, 2009 AT 2:30 PM
  • 109,896 POSTS
Have you checked fuel pump pressure and is the check engine light on?
Thursday, September 17th, 2009 AT 9:24 PM
MOEFEENEY
The check engine light is on and I haven't checked the fuel pump pressure, but I can hear the fuel pump kick on, I'm thinking it may be a clogged fuel filter which I'm going to try today. Any more suggestions would be great. Thanks!
Friday, September 18th, 2009 AT 7:13 AM
  • 109,896 POSTS
Try the filter. If that doesn't work, have the computer scanned. If the light is on, there is a code set that may tell you the problem. Most parts stores will do it for free. Also, after that, check pump pressure.
Friday, September 18th, 2009 AT 7:55 AM
