When I attempt to start the truck, it will roll over fine, but does not start. If I leave it sit for awhile (40 Minutes) it will sometimes start. Also, if I crank it, stop it, crank it over a number of times, it may start, as well. I tested the inertial switch, by jumping it, but that didn't do it. I have replaced the fuel filter, to no avail. When attempting a start, the anti-theft light does not come on, but the door locks engage, with the truck in park, and the door open. This happens when using either key fob. I have even removed the battery cables, let it sit for a bit, and it will start after that, not sure if that is coicidental or not.
Any thoughts?
Thanks much -Chris
SPONSORED LINKS
Monday, December 10th, 2007 AT 1:14 PM
