HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-150
Ignition
Coil
SPONSORED LINKS
2002 Ford F-150 # 5 cylinder
RENEEC
MEMBER
2002 FORD F-150
V8
4WD
AUTOMATIC
63,000 MILES
The # 5 cylinder is misfiring the coil pack is good what could it be?
Thursday, April 16th, 2009 AT 9:56 PM
BLACKOP555
MECHANIC
Bad injector. Bad compression? Not proper spark voltage and timing.
SPONSORED LINKS
Sunday, April 19th, 2009 AT 9:34 AM
BLACKOP555
MECHANIC
Also be the valves are burn a sticking or not seating properly.
Sunday, April 19th, 2009 AT 9:35 AM
Please
login
or
register
to post a reply.
Related Ignition Coil Content
2001 Ford F-150 Coil Pack
Can A Coil Pack Off 5.4 Litre Be Used On A 4.6. Litre?
Asked by
IceMan37
1 ANSWER
2001
FORD F-150
1986 Ford F-150 Ignition Coil Problems
Is There A Solenoid Switch Built Onto The Starter For An 1986 Ford F150 300ci. Or Is There Just Then One On The Fender? Also Does That Same...
Asked by
ttttttttttttttt
3 IMAGES
1986
FORD F-150
1982 Ford F150 Hot Coil
Why Is Coil Overheating And Vehicle Vapor Locking
Asked by
permitlady
1982
FORD F-150
94 Ford F-150 6cyl Won't Spark @ Coil
I Have A 94 Ford F-150 With 6 Cyl And Manual Trans. It Has 215,000 Miles. I Have Relpaced The Motor (3 Yrs Ago)and It Has Been Running...
Asked by
jackchurchill
1994
FORD F-150
Coil
1997 Ford F 150 5.4 Engine Over 100,000 Miles Question : I Have A Coil Going Out, My Mechinic Said Go Ahead And Drive It, It Won'thurt...
Asked by
Bruce Trebil
1 ANSWER
FORD F-150
VIEW MORE
SPONSORED LINKS
Crankshaft Sensor Symptoms
Crankshaft Sensor Replacement
Tune up
Online car repair manuals
