2000 Ford F-150 coil pack
KETYKEV
  • 2000 FORD F-150
Engine Performance problem
2000 Ford F150 V8 Two Wheel Drive Automatic 130k miles
I went to change my plugs & one of those dang 7mm coil pack bolts broke off. I tried tapping it out and broke off the whole assembley. I was still able to put the plug in and truck ran for awhile but no it feels like it is missing. It is real bad accelerating fast and going up hills. Coil pack is on just not bolted down. I hope you tell me its something else. Thanks because I love my truck
Thursday, February 12th, 2009 AT 7:07 PM
DON OLIVER
  • 101 POSTS
The coil pack doesn't have to bolted down. Lyour miss is from something else. The plug boot will hold the coil in position. Obviously you should repair it properly. You might have to get a valve cover if its that style or a manifold if its that style. Do a little more diagnostics. Goodluck
Thursday, February 12th, 2009 AT 7:27 PM
