2000 Ford F-150 Coil on plug?
SDIXON3
  • 2000 FORD F-150
  • V8
  • 4WD
  • 85,000 MILES
I had #8 coil on plug go out. I replaced it with a new one myself (I however didnt use dielectric grease) right after changing it, it ran great but I picked up an intermittant flutter/spark knock while accelerating. It only started after I replaced the coil. You can cut truck off and back on and it quits fluttering. Could me not using the grease be causing this problem, like I said it started soon as I changed the coil. Thanks in advance for any answer! ---Sean
Friday, September 4th, 2009 AT 3:36 PM
Could be it without the dielectric grease if not check the sparkplug, compression and injector for that cylinder.
Friday, September 4th, 2009 AT 3:48 PM
SDIXON3
The grease did fix it---thank you so much!
Sunday, September 6th, 2009 AT 4:56 PM
