I have a 1998 Ford F150. The passenger pwr window quit working some time ago. Recently the driver side window has quit working. I did measure voltage at the motor and it was just under 9v. The weather turned much cooler and for some reason the window started working again. Then it stopped. Then it was good for 2 days. Now it does not work again. I did NOT get a chance to meas the voltage at the motor while it was working. That's my bad. I am thinking I have a low voltage at motor problem and maybe not a bad motor. What do you think? Is there a voltage regular going to these window motors that could be defective? What shall I try next?
SPONSORED LINKS
Monday, October 13th, 2008 AT 10:26 PM
