2003 Ford F150 POWER WINDOW REPAIR PASSINGER SIDE FRONT
45,000 MILES • V8 • 2WD • AUTOMATIC
BILL64
HOW DO I CHECK THE MOTOR TO SEE IF IT GOOD
Jul 17, 2009 at 3:36 AM
BMRFIXIT
  • 19,053 POSTS
Check for power and ground at the motor plug
hold switch in one position (down or up )
you should have power at one wire and ground at the other wire (at window motor plug ,wire disconnected )
if so motor no good if not suspect bad switch and or wiring
Jul 17, 2009 at 3:20 PM
EWESSO
[quote:faa7617ec9="bill64"]Electrical problem
2003 Ford F150 V8 Two Wheel Drive Automatic 45000 miles
HOW DO I CHECK THE MOTOR TO SEE IF IT GOOD[/quote:faa7617ec9]
You unplug the motor and using a power source, ie battery charger or jumper cables from battery apply votage to the unpluged motor leads, the motor should operate switch the wires and the motor shold operate in reverse
Aug 24, 2009 at 2:56 PM
