When I turn the key to start the truck, the 15 amp ignition fuse blows. The battery will go dead overnight if I leave it connected, even when ignition switch is off. I replaced ignition switch. Same problem. If I jump off the starter solenoid while ignition key is on, the truck will l start right up. Would there be a short in the starter solenoid or the starter relay? Or something else?
SPONSORED LINKS
Thursday, February 19th, 2009 AT 6:38 AM
