1997 Ford F-150
DENNISRAY
  • 1997 FORD F-150
  • V8
  • 204,719 MILES
1997 f150 speedometer quit replaced sensor still not working is cluster panel replacement next step
Saturday, February 2nd, 2008 AT 4:03 PM
BLACKOP555
  • 10,371 POSTS
Chances are is the cluster is no more good, you have to have a dealer replace it as it has to be reprogrammed, only by them.
Saturday, February 2nd, 2008 AT 8:45 PM
DENNISRAY
What exactly needs to be reprogram is it just the odometer reading I would like to avoid the dealer and install a used panel from salvage yard is this possible
Sunday, February 10th, 2008 AT 11:14 AM
BLACKOP555
  • 10,371 POSTS
You MAY be able to put in one found in a junk yard and it MAY work without having it programmed for your sensors.
You can always replace it and bring it to a dealership and have it programed it would take all but 30 mins.
Sunday, February 10th, 2008 AT 3:14 PM
