U have to remove cluster out and bulbs in the back of it
1. Disconnect negative battery cable. Unsnap and remove instrument cluster opening finish panels.
2. On A/T models, remove loop on shift indicator cable from ball stud on shift lever.
3. Remove thumbwheel bracket screw.
. Detach bracket from steering column.
Remove cluster finish panel.
Remove 4 cluster screws.
Pull cluster away from panel, bottom first. Unplug connectors and remove instrument cluster.
Remove bulb and replace
To install, reverse removal procedure.
SPONSORED LINKS
Sunday, September 21st, 2008 AT 5:55 AM
