Check Gauges
2005 FORD F-150
76,000 MILES • V8 • 2WD • AUTOMATIC
TRISTAR138
I had the battery replaced on Saturday and the vehicle was running fine. On Sunday I drove the truck and parked it for about an hour. When I went out the vehicle would not start. It will not crank and there is a message to "CHECK GAUGES". The owner manual tells me that the coolant temperature could be high or the oil pressure low or the fuel level low. None of these apply. Can I reset the fault to get rid of the message.
Sep 13, 2010 at 4:50 AM
BMRFIXIT
  • 19,053 POSTS
It sounds like you have a battery that has gone bad and the voltage gauge has picked that up here is a guide to confirm the issue.
And if bad
https://www.2carpros.com/articles/how-to-replace-a-car-battery
Sep 13, 2010 at 11:36 AM
VESTALSIN
Thanks for this post I had this problem and fixed it with a new battery, I love this site
Jun 12, 2019 at 10:49 AM
