Thanks,
cwjaxon
Check cam and crank timing before replacing parts. Remove the No. 1 spark plug, rotate the engine until the TDC mark on the harmonic balancer aligns with the pointer, then remove the distributor cap and confirm the rotor points at cylinder No. 1. If it does not, suspect a jumped timing chain and gears. The ignition module on the heat sink left of the radiator was also suggested, but verified spark makes the timing check the better next step.
A 1996 Ford Thunderbird 3.8L lost power after a DPFE hose blew off and now cranks but will not start. The plugs are fuel-fouled, spark is present, and there are no codes; the catalytic converters rattle. Compression readings on cylinders 4 and 5 rise to about 130 psi and then drop with each cranking pulse. An expert first suggested the ignition module, then recommended checking whether the timing chain jumped by verifying that the distributor rotor points to cylinder No. 1 at TDC.
