1996 Ford F-150 96 F-150 will not start
F15096
  • 1996 FORD F-150
  • V8
  • 200,000 MILES
My truck 96 F150 5.0 will not start, just cranks. NEW (not used) parts as follows:
Fuel pump and filter
Distributor
Module
Crank position sensor
computer
I also swapped coil, and coil wire from a running car, no change. Fuel pump is running.
What I do know is we have no cranking RPM signal
Tuesday, April 27th, 2010 AT 3:48 PM
You need to continue to troubleshoot the ignition system-You sure it has a crankshaft position sensor
Tuesday, April 27th, 2010 AT 4:14 PM
F15096
Crank sensor was replaced by me when I did the water pump last week. So, Yes, it is there
Tuesday, April 27th, 2010 AT 4:20 PM
You have replaced a portion of the ignition system -Are you getting spark?
Tuesday, April 27th, 2010 AT 4:42 PM
F15096
Distributor, module, crank sensor, and computer are changed, no spark.
Scan shows no cranking RPM
Tuesday, April 27th, 2010 AT 4:58 PM
Test the ignition coil
Wednesday, April 28th, 2010 AT 1:21 PM
F15096
Swapped coil and coil wire from running car. Same result. No cranking rpm signal. I think there is a short in the wiring from the distributor to the computer.
Wednesday, April 28th, 2010 AT 1:53 PM
