Check engine light on?
Have the computer scanned for code/s-you have a problem within the engine management system that caused the CEL to turn on-This is your starting point of diagnosis, finding out what's going on.
Thursday, September 10th, 2020 AT 10:04 AM (Merged)
NATERGATOR
  • 1995 FORD F-150
I have a 95 f150 that has been intermittantly been giving the check engine light and the code is 327 I was told by the shop that the 327 code is a bad egr valve. I've been warned that they tell you it is something and try to sell you those parts even though that may not be the real cause of the trouble code. Any answers as to what 327 could really be?
The 327 is for the DPFE sensor I will change it-this is the one that samples the flow and tells the computer how to control the EGR.
NATERGATOR
The 327 is for the DPFE sensor I will change it-this is the one that samples the flow and tells the computer how to control the EGR.[/Quote:0a66f76d35]
so it would be safe to say that a simple cleaning to remove carbon buildup might solve the problem?
The 327 is for the DPFE sensor I will change it-this is the one that samples the flow and tells the computer how to control the EGR.[/Quote:e11e64b350]
so it would be safe to say that a simple cleaning to remove carbon buildup might solve the problem?[/Quote:e11e64b350]
Could be what causing the problem.
CURTISG007
  • 1995 FORD F-150
  • V8
  • 124,516 MILES
Check Engine light came on and motor stop running. It will turn over but want start
  • 31,937 POSTS
HI there,
The first thing you will have to do is get a scan and report back the set fault codes, I will need these to start the diagnostic process.
Mark (mhpautos)
ANTHONY WHEELER
  • 1995 FORD F-150
  • V8
  • 4WD
  • 183,000 MILES
CHECK ENGINE LIGHT FLASHES 4 TIMES AFTER STARTING. IT ALSO CUTS OUT WHEN MOVING FORWARD(KIND OF LIKE A DEAD SPOT)ALMOST AS IF IT LOSES FUEL AND THEN COMES RIGHT BACK.
  • 109,885 POSTS
I suggest taking it to a nationally recognized parts store and have them scan the computer for codes. Most stores will do it for free, and then we'll know exactly what direction to go.
CHOFFMAN41
  • 11 POSTS
  • 1995 FORD F-150
  • V8
  • 4WD
  • 91,000 MILES
Truck runs OK normally although doesn't seem real powerful for a 5.7 V-8. When I am towing a travel trailer, about 4000#, the check engine light comes on a lot, especially on hills. Truck has 3.55 gears and stock diameter tires. Light goes out after a short rest. Could an iffy cat. Converter cause this? Thanks.
BLACKOP555
  • 10,371 POSTS
Get the check engien light checked first, it is probably storing a code.
I hope its just not a missfire code.
May tell us what is wrong.
CHOFFMAN41
  • 11 POSTS
Got a 172 and 176 code for the o2 sensors on both sides. Also says system is/was lean. Don't know if the code means o2 sensors ARE bad and system is/was lean, or possibly one or the other.
BLACKOP555
  • 10,371 POSTS
Dotn think a cat would be causing it now, would suspect maybe faulty fuel pump or regulator, maybe dirty injectors causing the vehicle to lack in getting fuel due to the strain of pulling and going up hills!
Maybe a exhaust leak or faulty MAF sensor.
DALE32003
  • 1995 FORD F-150
Computer problem
1995 Ford F150 6 cyl Four Wheel Drive Manual
where is the plug to plug the code reader in to my 95 ford f150
In left rear of engine compartment,on bracket.
It is the VIP Test Connectors.
https://www.2carpros.com/forum/automotive_pictures/12900_dc_1.jpg
