1996 Ford F150 check engine light
1996 FORD F-150
BEVERLYHOOTEN
Engine Mechanical problem
1996 Ford F150 6 cyl Two Wheel Drive Manual
the codes are P0171, and P0174. what are they and how do you fix it.
Jul 1, 2010 at 1:19 PM
BLUELIGHTNIN6
  • 16,542 POSTS
need to replace your vehicle's oxygen sensors
Jul 1, 2010 at 1:30 PM
Lean fuel condition could be caused by one of the following below:
1.Vacuum leaks
2.EGR and PCV valve.
3.Low fuel pressure.
4.Dirty fuel injectors.
5.Mass Air Flow Sensor.
6.Oxygen Sensor.
Jul 1, 2010 at 1:31 PM
