1996 Ford F-150 check engine light.
DEVINB
  • 1996 FORD F-150
I own a 1996 Ford F-150 truck, 5.0 litre, w/113k miles. The check engine light just came on recently and I took it to AutoZone and had them put a diagnostic analizer on it and it didnt reveal a specific code, but rather just said that it was a "lean mixture". He concluded it couldve been something as simple as a tank of bad gas in the past and the computer just kept that in its memory. So he reset it and the light went off. But a day later and its back on. The engine does not appear to be running rough or anything. Just wondering what you think this could be. Ive tried un-hooking the battery for a while and letting the computer reset itself, but that didnt work either. Thanks in advance.
Saturday, July 7th, 2007 AT 2:50 PM
MERLIN2021
  • 17,250 POSTS
Check for vacuum leaks! Get a can of gumout and spray around. When the idle changes, you're on the right track!
Sunday, July 8th, 2007 AT 8:56 AM
