1995 Ford F150 V8 Automatic
I have a re occuring issue with starting. Turn the key and get click, repeatedly, but usually it will finally start.
I have had the battery tested under load, checks OK.
I have checked and rechecked the connectins for corosion, and replaced the terminal connectors at the battery. I have replaced the starter several times. Solenoid is on the starter. Whenever I have a problem with this and it simply won't start, just clicks, I have replaced the starter and the problem goes away for a very short time, sometimes a few weeks, sometimes a few days, but it always comes back. I have replaced the starter 5 times, the one in there is a OEM.
SPONSORED LINKS
Friday, December 25th, 2009 AT 10:55 AM
