Starting problem
STUCKINOHIO
  • 1990 FORD F-150
  • V8
  • 160,000 MILES
Will start and run fine when cool although has a high idle and hesitates when accelerated. The truck will not start once the engine is hot. After the truck cools will start again.
Saturday, March 14th, 2009 AT 5:10 PM
RACEFAN966
  • 5,029 POSTS
I would check the ignition module mounted on the side of the distributor or if it is not on the distributor then it is on a plate on the left fender. Here is what it will look like.
https://www.2carpros.com/forum/automotive_pictures/249564_101755_1.jpg
Monday, May 31st, 2021 AT 12:46 PM
