1990 Ford F-150 engine won't start
JBARNHART
  • 1990 FORD F-150
  • 6 CYL
  • 85,000 MILES
Was running fine last week. Came home Friday night. Went out Sat. AM and it wouldn't start. Engine turns over fine. Headlights bright. Has no spark and I cannot hear the fuel pump humming when I first turn key on. I replaced plugs, dist. Cap, rotor and wires. I also charged up the battery.
Wednesday, June 25th, 2008 AT 10:10 AM
DOCFIXIT
  • 18,828 POSTS
Check relay if it clicks when you turn the key. Also I think on the fuel rail see if there is a test prot ifr so depress se if there is fuel.
Wednesday, June 25th, 2008 AT 10:21 AM
JBARNHART
I also have no spark to the plugs. Could it be the ignition switch?
Wednesday, June 25th, 2008 AT 1:34 PM
DOCFIXIT
  • 18,828 POSTS
See if there is spark out of coil
Wednesday, June 25th, 2008 AT 1:46 PM
