1990 Ford F-150 no spark
MIKLLO69
  • 1990 FORD F-150
Engine Performance problem
1990 Ford F150 6 cyl Two Wheel Drive Automatic
have new wire plugs igniton ciol siloind gets fuel but no spark need help
Tuesday, June 8th, 2010 AT 2:30 PM
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Tuesday, June 8th, 2010 AT 5:29 PM
MIKLLO69
I changed the 2 coils and the distribator cap and roider also the plugs and wires. It just is not getting spark from the inginition coil to the plugs.
Thursday, June 10th, 2010 AT 9:47 PM
Check and test the distributor pick-up coil and the ignition control module
Thursday, June 10th, 2010 AT 9:50 PM
