1990 Ford F-150 dismantle 1990 Ford F-150 steering column
VIKINGBJ
  • 1990 FORD F-150
  • V8
  • 150,000 MILES
I have what I think is a broken upper ignition acuator that is broke. Very low on cash and trying to fix this myself.
I have tilt steering and am hiaving trouble dismantling. I could use directions or a good schematic. I have the steering wheel pulled and every #$%%% screw and pin I can see removed but the upper shroud will not budge.
Looking for any help. Thanks
Friday, January 18th, 2008 AT 4:31 PM
JWALTH02
  • 180 POSTS
First, did you remove the dash cover? Makes it a lot easier.
Second, did you remove the lock cylinder and the gear inside of it?
Let me know and we'll go from there.
Saturday, January 19th, 2008 AT 6:43 AM
VIKINGBJ
Saturday, January 19th, 2008 AT 8:02 AM
VIKINGBJ
I have removed all plastic dash pieces and plastic column shrouds. I had the lock cylinder and gear out but seemed not to help. I can do it again.
When I did that I removed the small plate above the upper acuator thinking the actuator would slide out. "No go"
I have removed turn signal part, the 3 screws in upper shroud. I have removed the 2 hex head screws under the bottom shroud. I am perplexed.
Your response is very appreciated and important
Saturday, January 19th, 2008 AT 8:05 AM
