1989 Ford F150 V8 Two Wheel Drive Automatic
i have a 1989 ford f150 and my fuel pumps were not shuting off so I wired a toggle into it and it was working fine and then I parked my car and went a little later to leave and it would not start so I tested the Inertia switch and the brown wire the had consent power when I first looked at it now doesnt and all I did was wired in a switch in between the pink wire and it worked and now it doesnt should I replace the relay or what eles could it be?
thanks
SPONSORED LINKS
Tuesday, February 17th, 2009 AT 2:40 PM
