HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-150
Fuel System
Fuel Pump
Relay
1997 Ford F-150 Fuel relay
H0TSH0T
MEMBER
1997 FORD F-150
6 CYL
2WD
MANUAL
121,000 MILES
I can't figure out were the fuel relay is on my truck. Can you help me.
Monday, February 8th, 2010 AT 3:52 PM
JDL
MECHANIC
Hi, should be under the hood, driver side, power distribution box.
Monday, February 8th, 2010 AT 3:57 PM
H0TSH0T
MEMBER
I meant the reset button for the fuel after an airbag deployment
Monday, February 8th, 2010 AT 5:18 PM
MIKEHARLOW
MEMBER
Try passenger side kick panel, red button
Monday, February 8th, 2010 AT 9:47 PM
H0TSH0T
MEMBER
It was there, THank You.
Monday, February 8th, 2010 AT 9:52 PM
Please
login
or
register
to post a reply.
Related Fuel System Fuel Pump Relay Content
Why Is There Only 6 Volts Comming Out Of The Fuel...
I Have A Ford F-150 1994 300 6cyl 4.9l Fuel Injected Twin Tank Truck, Yester Day While Driving It Just Shut Off, I Hot Wired The Fuel...
Asked by
RickB
1994
FORD F-150
VIDEO
Replace Your Fuel Pump Relay - Easy Steps
Instructional repair video
1999 Ford F150 Fuel System
My Truck Does Not Start When It Is Hot Outside - Especially If Parked In The Sun. If It Is Cool Out (60's) It Start Fine And Runs Great....
Asked by
Nwilley
1999
FORD F-150
The Inline Pump Continue To Run With The Switch Off?
My Truck Has Dual Tanks And Which Ever Tank Is Selected And The Inline Pump Continue To Run With The Switch Off Also The Relay Buzzs While...
Asked by
dixon1
7 IMAGES
1987
FORD F-150
It Will Start And Run For A Few Minutes Then Seems...
I Have A Truck That Will Not Start. I Wired The Fuel Pump Directly To The Fuse Box To Infuse That Only Comes On When The Ignition Is On. It...
Asked by
Christopher Masters
2 IMAGES
1989
FORD F-150
03 F150 Heritage, No Power At Fuel Pump.
Hi Guys, Ive Got An 03 Ford F150 Heritage Truck V6, No Power At Fuel Pump, Checked All Relays And Fuses Also, Checked The Inertia Switch...
Asked by
pearlhickory
2003
FORD F-150
VIEW MORE
How to Use a Test Light
Fuel Pump Replacement
How to fix an engine that wont start
