won't start some of the time
GRTROLLER
I have a 1994 explorer limited with the 4.0 engine and 165000 miles. Last year it got to where it would turn over but wouldn't start at times but would start after waiting a little while. Then it got to where it would crank but wouldn't start at all. I replaced the coil pack and plug wires, cleaned the maf sensor and it solved the problem. Now it is starting to come back but very rarely but will start after waiting the same amount of time as before. The maf was cleaned again before the problem returned. What else can I look at that could be causing this problem? If it maters the trans was rebuilt a few months before the problem started.
Apr 30, 2007 at 5:22 PM
2CARPRO JACK
  • 11,533 POSTS
When the truck doesnt start is it lacking fuel or spark? I would probably start with a fuel pressure test. Sometimes the pumps are weak or turn on intermittenly when they are going out.Like a bad starter, sometimes it works, sometimes not. I personally havent had much luck with cleaning MAF's, nothing very long term anyway.
May 1, 2007 at 1:03 AM
