1996 Ford Explorer Misfire Exhaust Smell
I HAVE NO PMT
1996 explorer sport 6cyl 186,000mi. auto. Runs as if plug wires are starting to go bad (shake/miss fire but light). Wires and plugs good. Has loss of power stomp on gas and it will restore power. Has very strong exhaust smell. Light has been on due to EGR sys. before this prob started.
Oct 18, 2007 at 4:52 AM
CHEVY22
  • 1,375 POSTS
fix the egr problem and see what happens , this could be the cause of the problem
jim
Oct 18, 2007 at 8:14 AM
Suggested Repair
Repair the existing EGR system fault first, then recheck the misfire, power loss, and strong exhaust smell.
Conversation Summary
The owner of a 1996 Ford Explorer reports a light misfire, power loss that improves when the throttle is pressed hard, and a strong exhaust smell. The plugs and wires were already checked, and the check engine light had been on for an EGR fault before these symptoms began. The expert advises fixing the EGR problem and then seeing whether the drivability issues remain.
