Replace a 2002 Explorer heater.
2002 FORD EXPLORER
MYATTCHRIS
I am installing a Mojave heater in my 2002 Ford Explorer [it costs $1000 to have dealer replace the $15 stripped plastic thingy under the dash]. I simply want to know how to identify the in and out hoses at the firewall under the hood. For what its worth, they have ID and OD printed on them. ALSO, will the water flow through the Mojave heater once the hoses are reconnected to it w/o any further action. I have just made a small donation.
Nov 7, 2007 at 2:27 AM
  • 55,423 POSTS
Hi, the heater hoses end at the fire wall, the heater core hose ends are what stick through the fire wall, to hook up the Mojave heater you must route new hoses inside the car to the new heater, coolant will flow ok through the new heater, hope this helps :D
Nov 7, 2007 at 4:19 AM
