NO HEAT COMING OUT OF VENTS
JAMES RANDY
  • FORD EXPLORER
I HAVE A 98 FORD EXPORER EDDIE BOUER, I AM NOT GETTING ANY HEAT COMING OUT THROUGHT THE VENTS, BUT IT IS BLOWING OUT COLD AIR. THE CAR HAS 125,000 MILES AND HAS A 5.0 ENGINE.
Sunday, November 4th, 2007 AT 1:52 PM
BLACKOP555
  • 10,371 POSTS
I would like you to check is is after runing it for a while feel the heater core hoses that go into the fire wall in and out, and if they are both hot then check the blend door inside the vehicle. If one or non is hot then you may have to bleed the coolant system. If that does not remedy flush out the heater core and make sure it is not pluged and then bleed it again.
Sunday, November 4th, 2007 AT 7:30 PM
