1994 Ford Explorer Intermittent Heater Blower Fix
BROX63
I Have a 1994 Explorer 4.0L about 92K miles. The heater blower works fine most of the time, However is seems that in the afternoon or night when we take the car out the blower wont come on. The next morning it has always worked. Any ideas? Could it be the relay? I believe it is in the fuse box under the hood. I think there is relays for the heater and A/C side by side. They appear to be plug in type similar to fuses. Do you think this could be my problem? Thanks for any info.
Feb 4, 2007 at 3:50 AM
SERVICE WRITER
  • 9,123 POSTS
It might be a relay, but I would expect the motor just based on typical outcomes. You can swap the two relays if they are the samw to see what changes happen or don't happen.
Feb 4, 2007 at 4:03 AM
BROX63
Thanks. Someone else told me it might be the blower motor. I Thought it would either work or not work. I didnt realize it could be intermittant.
Feb 6, 2007 at 6:56 AM
SERVICE WRITER
  • 9,123 POSTS
Oh yeah, they can be. There is a thing called the tap test where you rap on the right side of the dash or blower motor case to get it to work.....temporarily.
Feb 6, 2007 at 7:15 AM
Suggested Repair
Swap the matching heater and A/C relays to see whether the fault follows a relay. An intermittent blower motor is more likely; a temporary tap test on the right side of the dash or blower motor case can help confirm it.
Conversation Summary
The owner of a 1994 Ford Explorer reported that the heater blower usually works but sometimes will not come on in the afternoon or at night, then works again the next morning, and suspected a relay. The expert said a relay is possible and suggested swapping identical relays, but considered an intermittent blower motor more typical. The expert also noted that tapping the right side of the dash or blower motor case may make it work temporarily.
