2002 Ford Explorer Heater Clicking
TIMBOWEE
2002 FORD EXPLORER 4.0 LTR 4X4, 86,000 MILES
THE PROBLEM I'M HAVING IS SOUNDS LIKE A DOOR IS TRYING TO SHUT IN THE DASH WHEN THE HEATER IS ON. I HAVE TO TURN THE BLOWER KNOB TO LOW AND THEN SET THE TEMPATURE KNOB WHERE I WANT IT AND THEN ONE SPEED AT A TIME, TURN THE BLOWER ON HIGH. NOW THERE IS NO HEAT COMING OUT AT ALL BUT I CAN HERE A CLICKING NOISE IN THE DASH, BUT GOES AWAY WHEN I TURN THE AC ON. WHAT MIGHT THIS BE? THANKS
Apr 6, 2007 at 12:16 PM
TAURUSWHEEL
  • 718 POSTS
Try to get under the dash and check the blend door operation, maybe something is unhooked or electrical issue could have the door trying to open and close
Apr 8, 2007 at 7:02 AM
CHILLYINMI
That happened to me this morning on my 2003 explorer. Did you get it fixed? What was wrong?
Thanks! Cheryl
Apr 20, 2007 at 3:17 AM
TEX
sounds like the blend door actuator. The part runs around $50 but is quite involved to replace especially on a Lincoln Towncar. Don't know about the Ford Explorer. You have to pull the dash on the Towncar. The part is somewhere behind the glove box area.
Apr 22, 2007 at 10:48 AM
Suggested Repair
Inspect blend-door operation under the dash for a disconnected linkage or an electrical fault that keeps the door cycling. The clicking and loss of heat commonly indicate a failed blend-door actuator, often located behind the glove box; replacement is inexpensive but can require substantial dash work.
Conversation Summary
The owner of a 2002 Ford Explorer reports a clicking sound in the dash with the heater on, followed by no heat, though the click stops when the A/C is selected. An expert advises checking blend-door operation for a mechanical or electrical problem. Another reply identifies the blend-door actuator, noting the part is inexpensive but replacement can be involved and is often behind the glove box.
