1995 Ford Explorer Idle Drop and Stall
SCOOBYTECH
I have had several people look at this problem but no solutions yet.
1995 Ford Explorer 4.0 4WD with 205000 miles
Vehicle starts fine. Accelerates fine. When at cruising speed (constant speed) I notice some hesitation. When stopped at light, car will idle fine and then drop sharply and back up. It will do this repeatedly and then shut off. I was receiving some EGR codes that have not reappeared since changing EGR Valve. However the problem still remains. Could it be the PCM? If so, is there a way to test the PCM?
Items that have been replaced:
Ait Filter
Fuel Filter
Spark Plugs
PCV
TPS
EGR Valve
DFPS Differential Feedback Pressure Sensor
Idle Air Control Valve(motor?)
Throttle body has been cleaned.
Jun 18, 2007 at 6:35 AM
DONNY BRYSON
  • 13 POSTS
I would check the TPS and maybe your fuel pump could be getting weak.
Jun 18, 2007 at 11:18 AM
SCOOBYTECH
[quote:c0d30f0334="donny bryson"]I would check the TPS and maybe your fuel pump could be getting weak.[/quote:c0d30f0334]
I already changed the TPS with no results. If the fuel pump was getting weak, would it show on acceleration as well? Is there a way to test the pump besides testing the voltage?
Jun 19, 2007 at 9:29 AM
98RANGERXLT
  • 301 POSTS
If the fuel pump was getting weak you would know when you fill up the vehicle will cut off and on
Jun 19, 2007 at 1:27 PM
SCOOBYTECH
[quote:4a12a71238="Fordman16"]If the fuel pump was getting weak you would know when you fill up the vehicle will cut off and on[/quote:4a12a71238]
I haven't noticed that when I fill up. I will see on the next fill up.
I was thinking it might be the MAF sensor? I checked the voltage TO the sensor(at the MAF connection with KOEO) and I am receiving 5.83 volts. According to the Haynes manual, I should be getting battery level voltage (anywhere from 10 to 12).
Is this true?
If so, could this be the problem.
A short or maybe a bad PCM?
Thanks for your feedback!
Jun 20, 2007 at 12:14 AM
98RANGERXLT
  • 301 POSTS
Also there is a sock on the end of the fuel pump that will get dirty check that also.
Jun 20, 2007 at 12:41 PM
Suggested Repair
Check the fuel pump sock for dirt and test whether the fuel pump is weak, especially if the engine cuts out after fill-ups. The TPS was already replaced without fixing the idle drop and stall.
Conversation Summary
A 1995 Ford Explorer 4.0 starts and accelerates normally but hesitates at steady cruise speed, then repeatedly drops idle and stalls at stops. The owner replaced the air filter, fuel filter, plugs, PCV, TPS, EGR valve, DPFE sensor, and idle air control valve, and cleaned the throttle body, but the problem remained. Experts suggested a weak fuel pump and a dirty sock on the pump. The owner had not noticed cutoff after fill-ups and also questioned a low MAF supply voltage reading, but that was not confirmed as the cause.
