2000 Ford Explore with a 4.0 engine. Car wouold start but would not stay running at idle speed. Turned the idle screw up to where oit would idle normal knowing that wasn't going to fix the problem but would get me thru the day. Car ran fine that day but if you revved the engine it would come back to a high idle for a couple seconds and then to a normal idle. The next day the car won't idle again.
Nov 17, 2006 at 4:17 AM
