When I start it it starts then goes to 500 rpm or below then stalls out but then I start it again give it gas but then it goes back to 500 rpm then stalls again then I repeat by giving it gas till it warms up then I drive a mile or two then its good the rest of the day. What is the problem with it? And I have read forums about it and they say it happend to them and it the IAC or the camshaft sensor what should I do?
SPONSORED LINKS
Tuesday, September 4th, 2007 AT 1:15 PM
MERLIN2021
MECHANIC
Knowing the mileage would help, but try unplggin your MAF and going for a short drive.
Tuesday, September 4th, 2007 AT 1:36 PM
WHITESA90
MEMBER
It has 161, xxx miles on it
SPONSORED LINKS
Tuesday, September 4th, 2007 AT 6:43 PM
MERLIN2021
MECHANIC
Plenty of miles to ruin a MAF! Test it
Wednesday, September 5th, 2007 AT 6:14 PM
TV MAN
MEMBER
How do you test a MAF?
Thursday, October 18th, 2007 AT 6:52 AM
MERLIN2021
MECHANIC
You'll need a scantool you can monitor as you drive...here's the chart! Or just unplug and go for a short ride, if driveability improves, replace it!
