Can a missing balance weight cause a vehicle to pull hard to one side??
Dec 7, 2006 at 12:02 PM
A missing balance weight is unlikely to cause a hard pull and more often affects tire wear. Check wheel alignment and for a dragging brake; also inspect the steering box and linkage if there is play or wander.
The owner of a 2001 Ford Explorer Sport asked whether a missing balance weight could make the vehicle pull hard to one side. A reply suggested a loose steering box, worn steering linkage, or insufficient toe-in. The expert said imbalance is unlikely to be noticeable and usually mainly affects tire wear, and pointed to alignment or a dragging brake as more likely causes.
