1993 Ford Explorer Hard Ride on Bumps
ROSAANGE
hi i have a 93 ford explorer four door, what do i need to change if i want my truck to run smooth while driving? also every time i go in a bump the truck feels like it hits really hard what do i need to do to stop that.
Jun 13, 2006 at 2:09 PM
LSUSSEL
  • 252 POSTS
What do you mean run smooth? What does it do when you drive? when you hit the bumps and it sounds like that it could be many things. shocks, old tires,brakes or even your front end. have you kept up with all your regular matainence?
Jun 13, 2006 at 3:39 PM
ROSAANGE
When ever im driving i dont want to feel every little thing i hit i want it to be a smooth ride i recently changed my tires and brakes could it be the shocks what exactly do the shocks do?
Jun 16, 2006 at 3:38 AM
SYNCRAIT
  • 235 POSTS
they help cushon the recoil from the springs absorbing the bumps...
Jun 16, 2006 at 3:44 AM
TAURUSWHEEL
  • 718 POSTS
Unfortunately. 13 year old vehicles are not as tight as new.. it's possible the shocks are not taking the initial shot very well and responding quickly enough,, about par for the course if the shocks are that old, are they original?? you could change them. however I wouldn't get my hopes up for that like-new ride,, my vehicles have their own set of creaks and groans.
Jun 17, 2006 at 1:51 AM
Suggested Repair
Inspect and replace worn or original shocks, which damp spring rebound and the initial impact of bumps. Also check front-end wear. New tires and brakes alone will not restore a new-vehicle ride on a 13-year-old Explorer.
Conversation Summary
The owner of a 1993 Ford Explorer wants a smoother ride and says the truck hits hard over bumps after recent tire and brake work. Experts explain that shocks cushion spring recoil, note that aged or original shocks often respond poorly, and say replacement may help but will not make an older vehicle ride like new. Other possible causes include front-end wear.
