Ford Explorer Won't Start
RUSSFIELDING
First, thank you very much for your help. Here's my update. I tested for a spark and it is there. I listened to the fuel pump and heard it humming. My plan now is to replace the fuel filter because the car has 195k miles and is probably on its original filter anyway. I'll replace the air filter while I'm at it. If that doesn't clear up the problem, I'm going to take it in and have the fuel pressure tested to see if maybe the pump has gone bad. Is there anything else that could be causing the problem. Engines only need three things, as far as I know: fuel, spark, and air. Is it possible that the computer could be sensing an error and preventing the car from starting? Thanks again.
Apr 14, 2007 at 3:36 AM
MERLIN2021
  • 17,250 POSTS
Three things needed to start are Spark, Gas, Compression! Check you engines compression! To test the spark use a spark plug with the right gap and crank away!
Apr 15, 2007 at 3:13 AM
BIGNICK
  • 14 POSTS
Just because you hear humming from the fuel pump dosen't mean the pump is working correctly. It could be weak, or the regulator could be bad. Try disconnecting the air intake tube and spraying starting fluid into it. If it starts and dies right away, then you might have a pump/regulator problem.
Apr 15, 2007 at 3:22 AM
Suggested Repair
Check engine compression and confirm spark with a properly gapped spark plug. Because a humming fuel pump may still be weak, spray starting fluid into the intake; if it starts and dies, test fuel pressure and inspect the pump and regulator.
Conversation Summary
A Ford Explorer will not start even though spark is present and the fuel pump hums. The owner planned to replace the fuel and air filters and then have fuel pressure tested. Advice was to verify compression and spark with a correctly gapped plug, and to use starting fluid to check whether a weak pump or bad regulator is causing a fuel delivery problem.
