Ford Explorer Jerks to the Right
AKLENNERT
Hi, my explorer jerks to the right while I'm driving. I've been told that it may be the tie rod, the wheel bearing or the coil inside the hub. What do you think I should check first?????
Jul 6, 2006 at 2:20 AM
TAURUSWHEEL
  • 718 POSTS
It does this every time out??? Not that it matters much, I would take it, immediately, and have it checked out before you take yourself out.. years ago I had a front wheel bearing let go on the highway, no warning of any issue, I went off the right side, luckily there was a wide swath of grass, no hard obstacles,,, not saying yours is the bearing, get it checked pronto
Jul 6, 2006 at 2:14 PM
Suggested Repair
Stop driving and have the Explorer professionally inspected immediately. A sudden steering or wheel-bearing failure can cause loss of control; the expert did not identify a specific part.
Conversation Summary
The owner reports a Ford Explorer that jerks to the right while driving and was told it might be a tie rod, wheel bearing, or hub coil. The expert urges an immediate professional inspection because a failed front wheel bearing can cause a sudden loss of control, without diagnosing a specific part.
