1991 Ford Explorer Cold No-Crank
STGREEN47546
I have a 1991 Ford explorer xl 4x4 with a 4.0 v6 and when it is really cold outside it won't turn over. usually it is just a little slow to turn over, but the colder it gets the worse it is. today it is really cold out and it won't turn over at all. what can i try to get it started?
Feb 13, 2007 at 1:54 PM
  • 75,988 POSTS
Do you mean it cranks over and w/n start or when you turn key to start nothing happens Nada.
It sounds like a battery problem being affected by the cold weather, maybe wrong type of battery-not up to snuff with the CCA's or a real bad connections involved that the starter is not get its share of electrical pressure.
Happy Valentines Day-Good Luck!
Feb 13, 2007 at 9:20 PM
Suggested Repair
Check the battery for adequate cold-cranking amps and condition, and inspect battery and starter cable connections for corrosion or looseness that could starve the starter in cold weather.
Conversation Summary
The owner of a 1991 Ford Explorer XL 4x4 with a 4.0 V6 reports that the engine turns over slowly in cold weather and will not turn over at all in extreme cold. The expert asks whether it cranks without starting or does nothing, and suggests a weak or undersized battery, insufficient CCA, or poor electrical connections preventing the starter from getting enough power.
