1994 Ford Explorer Check Engine Light
JIHOLDEN
I have a 1994 Ford Explorer Sport. It runs fine, but has had the "Check Engine" light on for about 3 years. Any way I can turn it off? I want to sell the vehicle, and it is a false red flag. Many Thanks!
James
May 4, 2007 at 1:49 AM
BACKYARDMECHANIC
  • 337 POSTS
If the light has been on this long then there is something causing it to come on. Take it to a big chain autoparts store and have them pull the code for you. Most of them will do this for free. At least then you will know whats is wrong. You can also have them clear the code for you, but I suspect that the light will come back on shortly after. If there is a problem that the engine management system is detecting it will only turn the light back on again until the problem is fix. Good luck
May 4, 2007 at 6:00 AM
Suggested Repair
Have a parts store pull the check-engine code for free so the cause is known. Clearing the code may turn the light off briefly, but it will return until the detected fault is repaired.
Conversation Summary
The owner of a 1994 Ford Explorer Sport says it runs fine but the check engine light has been on for about three years and wants it off before selling. The expert says a long-standing light means a fault is being detected, recommends a free code scan at a chain parts store, and notes that clearing the code will not keep the light off until the problem is fixed.
