1995 Ford Explorer Battery Light On
DAWGEGUY
I replaced a alternator on a 1995 ford explorer about 149,000 miles, and now the gauge is working fine but the battery light is on and wont go off.
Nov 21, 2006 at 9:56 AM
BACKYARDMECHANIC
  • 337 POSTS
If the alternator is working properly, then make sure you connected all the wires or did not damage any wires after replacing the alternator. This is a fairly simply circuit that operates the Battery light. It starts at a fuse( Check this also) then goes to the battery light and ends at the alternator. Hope this helps
Backyardmechanic
Nov 27, 2006 at 6:18 AM
Suggested Repair
Confirm the alternator is charging, then inspect the battery-light circuit: check the fuse and verify every wire to the alternator is connected and undamaged.
Conversation Summary
After replacing the alternator on a 1995 Ford Explorer, the gauge works but the battery light stays on. The expert says the light circuit runs from a fuse through the battery light to the alternator, so check the fuse and make sure no wires were left disconnected or damaged during the replacement.
