96 explorer 4.0 engine 165,000 miles could it be grounds if is which 1 or ones :D
Nov 15, 2007 at 7:01 AM
Voltage-test the negative battery cable at the post and engine block. Expect battery voltage when not cranking and about 0.5 volts below battery voltage while cranking. Also test the battery, since a weak or low battery can destroy the alternator.
The owner of a 1996 Ford Explorer 4.0 with 165,000 miles reports four alternators failing in three weeks and asks whether bad grounds are responsible. The expert recommends voltage-testing the negative cable at the battery post and block, and notes that a weak or low battery can cause alternator failure.
