1995 Ford Explorer ABS Pushback
DOSCAL0219
I recently purchased a 1995 ford explorer (137,000 miles). I am having a problem with the ABS system. Just before I come to a complete stop I feel the brakes pushing back and making a hissing sound. I'm not having any issues stopping at all. This morning the brakes didn't push back but the ABS light came on. Now the ABS light is off again and the brake is pushing back again. I've been told it's many issues from a bad sensor to air in the brakes.
Feb 21, 2006 at 10:59 AM
2CARPRO BOB
  • 45 POSTS
Scan the PCM (Powertrain Control Module) for fault codes in the brake system but it sounds like you have a wheel sensor that is malfunctioning.
Feb 24, 2006 at 2:52 AM
Suggested Repair
Scan the PCM for brake-system fault codes. The symptoms point to a malfunctioning wheel speed sensor.
Conversation Summary
The owner of a 1995 Ford Explorer with 137,000 miles says the brakes push back and hiss just before a complete stop, though stopping is otherwise normal. The ABS light came on briefly when the pushback stopped, then went off as the pushback returned. An expert recommends scanning the PCM for brake fault codes and suspects a malfunctioning wheel sensor.
