1994 Ford Explorer abs warning light
180,000 MILES • 4 CYL • 2WD • MANUAL
EARL HARDWICK
new pads and shoes breaking seems normal but abs warning light flashes several times then stays on for a period then repeats the sme thing there are no leaks and all works and looks well how do icheck from here?
Jun 21, 2008 at 12:12 PM
BMRFIXIT
  • 19,053 POSTS
ABS system is different then your regular brake system and it work with it \
you need to have the ABS system module check for codes as that will help to pin point the troubled area
possible wheel sensor
with out the scanner you can check fuses and relays related to the ABS system
check around the tires sensors for loose or broken wires
check brake fluid and float in the master cylinder
you really need a scanner to have the system scanned
good luck
Jun 22, 2008 at 1:28 AM
