ABS light stays on?
104,000 MILES • 4 CYL • 4WD • AUTOMATIC
AIRBRNMIKE
ABS light stays on, had the rear sensor replaced by mechanic the code from the diagnostic computer suggested that was the problem. New rear sensor same problem. also is the outside temperature display available for the XLS trim? At start up the digits are there, but the odometer only shows mileage and trip mileage? I think outside temp is supposed to be there, maybe it was turned off... Thanks for your assistance.
Dec 22, 2009 at 6:50 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
It sounds that you might have fault codes stored in the ABS- anti lock brake system. The best thing for you to do is have a CAN scan- Controller Area Network performed to determine what fault codes are stored in your vehicles computer. Here is a tutorial showing what is involved with a CAN scan:
Once you have this performed get back to us with the code numbers and we can then properly diagnose the issues your vehicle is having. Hope this helps and thanks for using 2CarPros. We hope you will use our site again in the future when needed.
Aug 3, 2021 at 1:55 PM
