1999 Ford Explorer Ball Joints
SEANLELIAKACI
How do i determine if the ball joints in my 1999 Explorer xlt 4x4 need to be replaced? Are there any symptoms/noises I would hear? Wife took the car to be inspected yesterday and mechanic told her this.The truck has 118,000 miles on it. Can i check for anything by jacking the car in my driveway?
thanks anyone for assistance.
Aug 9, 2007 at 9:03 AM
MERLIN2021
  • 17,250 POSTS
Do you have a floor jack? if yes jack up under the control arm to take pressure off the ball joint. Get a good size bar and put it under the tire and pull up and down...see ANY movement? Movement is bad!
Aug 13, 2007 at 9:30 AM
Suggested Repair
Jack under the control arm to unload the ball joint, place a bar under the tire, and check for up-and-down movement. Any movement means the ball joint should be replaced.
Conversation Summary
The owner of a 1999 Ford Explorer XLT 4x4 with 118,000 miles asked how to confirm ball joints flagged during an inspection and what symptoms to notice. The expert advised jacking under the control arm and prying the tire up and down; any movement indicates a worn ball joint.
