1993 Ford Explorer Rear Wheel Locks Up
RUM01
I have a 1993 ford explorer which has 171,000 miles on it. My problem is the rear driver side tire will lock up when going forward. It will move in reverse, but as soon as I put it in drive, the rear tire locks and drags. Any help on this would be great.
Feb 27, 2006 at 10:36 AM
LOVESCARS
  • 359 POSTS
possible frozen e-brake cable or the wheel cylinder on the oposite side might night not be balancing the pressure.
have you used the e-brake recently. you can idenify brake drag by jacking one rear wheel and trying to spin then jack the other side and try the same.
Feb 27, 2006 at 12:18 PM
RUM01
Thanks for the reply. Yes i have been using the ebrake more recently, just moved and have to park on a hill. If it is the brake cable, how would I go about fixing it? Thanks again.
Feb 28, 2006 at 12:22 PM
LOVESCARS
  • 359 POSTS
you can buy a manual from this site.
the barkes are safety item and it's best left to someone certified if you are not already familiar with replacing them
Feb 28, 2006 at 12:26 PM
Suggested Repair
Check for a frozen or sticking parking-brake cable, especially after frequent use on a hill, and compare rear-wheel drag by jacking each side and trying to spin the wheel. Also check whether the opposite wheel cylinder is balancing brake pressure. Because brakes are a safety item, have a certified technician diagnose and repair them if you are not already familiar with the work.
Conversation Summary
The owner of a 1993 Ford Explorer says the rear driver-side tire locks and drags in drive but still moves in reverse. The expert suggests a frozen parking-brake cable or an unbalanced wheel cylinder and recommends comparing both rear wheels by jacking and spinning them. The owner has been using the parking brake more often while parking on a hill. The expert says brake work is a safety item and is best left to a certified person if the owner is not already familiar with it.
