1999 Ford Explorer Door Handle Rods
CARL KLEINE
DOES ANYONE HAVE ANY TIPS ON HOW TO INSTALL A DRIVERS SIDE EXTERIOR DOOR HANDLE ON A 1999 EXPLORER XLT.i CAN'T SEEM TO GET THE RODS HOOKED UP RIGHT
Dec 6, 2006 at 8:33 AM
2CARPRO JACK
  • 11,533 POSTS
If need be, look at the other side.I know its alot of work,but it will help you see where each rod goes.Sometimes a digital picture is a good idea before yopu take anything apart
Dec 6, 2006 at 10:25 AM
Suggested Repair
Compare the opposite door to see where each linkage rod connects. Photograph the handle and rods before disassembly so they can be reattached in the correct positions.
Conversation Summary
The owner of a 1999 Ford Explorer XLT is having trouble reconnecting the rods while installing a driver's side exterior door handle. The expert recommends comparing the other door and taking photos before taking the linkage apart.
