2002 Ford Explorer AWD Chatter on Turns
RINGLE
When turning hard right and accelerating there is a chatter similar to turning when in 4 wheel drive. The selector is in Auto when this occurs. It is intermitment and occurs more ofter when the car is warm but never severe only a slight chatter.
Is this likely an issue in the transfer gears/clutch or is it a sensor issue so that the AWD is being activated? Had a service shop check it today and they couldn't find an issue although they did notice the failure when test driving.
2002 Explorer Limited 94000 miles V8 4.6?
Nov 19, 2007 at 2:27 PM
MERLIN2021
  • 17,250 POSTS
try changing the oil in the front axle, and don't forget the additive, for the limited slip!
Nov 19, 2007 at 6:25 PM
Suggested Repair
Change the front axle oil and include the limited-slip additive.
Conversation Summary
A 2002 Ford Explorer Limited with about 94,000 miles chatters slightly on hard right turns while accelerating in Auto, more often when warm. A shop confirmed the symptom but found no fault. The expert suggested changing the front axle oil and using the limited-slip additive.
